Corsa exhaust diverter not staying shut - Capt Call/Silent Choice
I have the Corsa Captains Call on both my engines. Port engine fine. Stbd, one of the selonoids won't keep the diverter closed (quite mode) beyond a second or two. It just flips back to open mode while the other side keeps that diverter shut.
Anyone else have this happen, any ideas?
Thx in advance.
Thx in advance.
Thx in advance.
Thx in advance.
There's two different scenarios, 12v power to hold open or 12v power to hold closed. I assume your quiet mode is solenoids 12v power to close. In this case post #3 is your fix and/or they're not getting enough voltage. If your solenoids are held open with 12v power and opening when power is switched off then you'll need stiffer springs. It's easy to determine which you have, power on the ignition (engine off) and see what position drags the battery gauge down.
