Newbie question: explain drive showers to me
Originally posted by fund razor
Ok, so with the above in mind, is it as essential to use drive showers on Cobras? I swear these bastards hold 100 ounces of lube each.
My entire garbage can is filled with empty merc high perf bottles. Took about 3 bottles each Cobra drive.
(Oh yeah, and 33 ounces for my little boat with the alpha).
Look at the supply water path in the drive. Water does not go thru the top of the drive or the sides, so it is not cooled from the water supply.
Kinda explains why showers dump water on the top cap, and also the sides of the drive by the Simrek models.
Toxic FORMULA
OMC Cobra drives have much better oil circulation top to bottom than Mercs and don't suffer as much from the high temps. Plus the larger capacity is also a help. I've never seen a Cobra with chalky residue on the upper.
Say what you will about Cobras and King Cobras , but they DID have some good points over Mercruiser. This and the sea water pump being two of them.
bford1, I've also wondered about showers for my TRS drives. I've yet to come across any, the only ones I've found are for Alpha and Bravo.
Anyone know where or if these are available?
Thanks,
Brian
Thanks,
Brian
Why do you think there is such a market for after drives on high performance boats IMCO's SC, BMAX, etc..
They all have some type of water jacketed cases.
my .02
my .02
Originally posted by bford1
How about a drive shower for an old TRS? Do they make them or is it pretty much a universal fit?
go to http://www.driveshowers.com/
and the halo will fit trs drives. you can check it out on the webpage
Has anyone seen a "heat related" failure on a drive? Sure they fail but I have yet to see a failure that was due to heat.
Why are showers so important on a mass produced drive like the Bravo but not on a 3, 3A, 5, or 6 drive?
I personally do run them but I really wonder if it's just good marketing on the part of shower manufacturers.
dsmdude
4
08-16-2006 11:44 AM
