Newbie Question- Can I use a 90 Bravo one drive to replace a 96? >
Old 08-16-2006 | 01:01 AM
Default Newbie Question- Can I use a 90 Bravo one drive to replace a 96?
My bravo one went out on my 96 Baja and I was wondering, assuming the ratio is the same, can I use any year bravo (specificly a 1990) to replace it? The upper portion of the drive is shot and is pretty tore up- what usually causes this? The boat has about 500 hours on it and I will be selling it within the next few months to upgrade. Should I go with a drive shower on my next boat? Thanks in advance for all advice!
dsmdude is offline
Old 08-16-2006 | 05:54 AM
Payton's Avatar
Charter Member #927
Default Re: Newbie Question- Can I use a 90 Bravo one drive to replace a 96?
I don't see why you can't use it. Just don't sell it to anyone here on OSO.
Welcome to the board.
Payton is offline
Old 08-16-2006 | 07:32 AM
Zanie's Avatar
The 90 bravo isn't going to have the oil transfer port, but the 96 will.
If you are dumping it anyway, drill and tap the oil transfer port and put a pipe plug in it, or you'll have the biggest oil leak ever!
Zanie is offline
Old 08-16-2006 | 09:37 AM
Mine 90 does
I thougth it was only the first year the Bravo was made?
1BIGJIM is offline
Old 08-16-2006 | 11:44 AM
Wobble's Avatar
SORE MEMBER
if you are talking about a complete drive swap, then there should be no problem, a drive shower is a good idea for any Bravo.
Mixing some year uppers and lowers have some considerations as mentioned above.
Wobble is offline
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
bcoffield
5
07-11-2006 04:40 PM
cloudmaster_321
2
04-23-2005 07:34 PM
chuck21401
19
05-11-2004 02:26 PM
rws
5
12-07-2002 04:42 PM
