Dynos problems persist.....
#61
Re: Dynos problems persist.....
DO NOT DRAW IT WITH THE CRANK BOLT!!!!!! Use a damper install tool. I have seen to many times cranks with the threads pulled out do to this proceedure. Go to your local Napa and rent the tool. We sell thousands of these for a reason...............
Chris
Chris
#62
Chris
Chris
BT
#63
Do not use the original crank bolt, I use a longer bolt with a nut and large washer, thread the bolt in first then draw on with nut and washer, never had a problem.
#64
only will happen if your only catchin the first couple of threads. If you use a longer bolt and the mating surfaces are in good shape you'll be o.k.
#66
Charter Member #655
Hey man!!! Long time no hear from you.....gauges arent in yet ...been a ***** of a summer engines in, out, in, out, Started to put the gauges in a couple weeks ago and the bezels I bought from Eddie Marine were to wide....sent them back and havent got the new ones yet but will soon!!!! You up and runnin????
If your boat has a sail do you ride a horse to the ramp?
#67
Up and runnin now. Just tweaking her in. Lots and lots of little things but nothing to keep me from running. Not ready for poker runs yet.
Been doing a lot of work on other people's boats...just tyring to help but it's getting old.
