| OSO Sponsor |
| OSO Sponsor |
08-26-2008, 01:09 PM
Fountain 10 Meter
Looking for a SuperCat crank
I'm searching for a short-stroke (3.829") Callies Lightweight crank for Merc Supercat motor.
Anyone have one of these lying around? If so, please call me at 313 283-8148.
Thanks in Advance,
Brian
08-28-2008, 07:05 AM
Fountain 10 Meter
Ok, so I'm extending my search criteria... looking for a GOOD crank, with a stroke up to 3.875"
Apparently, those short-stroke Callies cranks in Supercat motors are an oddball cut, and I've broke two of them anyways.
Number is above if you can help.
Thanks,
Brian
08-28-2008, 05:33 PM
Geronimo36
36' Apache
Have you tried JCPERF?
May wanna look at getting the block line honed if it hasn't been already. Seem's weird!
Geronimo!!~
08-28-2008, 07:32 PM
Fountain 10 Meter
Weird? Sure is. If was the same motor, I'd be looking much more closely at the block, but they broke in different motors. Yes, they line honed them just to clean up crank bores.
Both cranks broke this season. Any ideas what causes a crank to break?
Thanks,
Brian
08-28-2008, 07:53 PM
39' Sea Ray, 38' Nortech, 18' Taylor SJ
Quote:
Thanks,
Brian
Bad Karma ??
Good luck.
08-29-2008, 10:20 AM
Geronimo36
36' Apache
Thanks,
Brian
Detonation, Age, Journals cut down too much, Harmonics/Balance, BAD LUCK... It could be so many things!
Geronimo!!~
09-04-2008, 08:17 PM
35 Fountain
Thanks,
Brian
Not enuff ballast! Just kidding good luck getting it back together. Let me know about Key West.
09-05-2008, 09:32 AM
94 43SC Black Thunder
Leave it to Mercury to come up with another oddball engine part. They could've used 427 cranks (3.76 stroke) instead
