staggered set up.
Registered User
hey powerplay fans, any suggestions for graphics on the 23' that was posted earlier(ac boat show). I want to remove the tribal and keep some old tradition, other than that I'm stumped. I'm new to this go fast, wicked cool looking sport.
Thhanks for the responses.We tried 4 blades and the boat accelerates better and handles better.We still have the same problem as far as lift is concerned.We knew that by adding a blade we would get more stern lift but we have not tried them spinning out yet.This boat has 598 cu in. and 750 hp.The drives are very close toguether,I believe 16.25 inch from prop shaft to prop shaft.We also have 12 inch extension boxes.What is the x dimension on other staggered set ups?
We are trying to settle it on the top end.The boat runs great until about 92 and then is a handful.Although if there is a slight chop the boat tends to track straight.
Again thanks for the help.
Wil
Wil
Wil, does that boat have green upholstery? If so ,Iwas in that boat with 29 pitch 3 blades in calm water. It got pretty loose over 90. It started to chine walk, and you really had to drive it. My boat has side by side and I spin them out. The boat never seems to have too much stern lift or get loose, so it may help yours as well. Since you are in Fl. I would see what Matt and Julie at Throttle Up can help you with.Good luck!
PP33,
It does have green upholstery.The boat was in Virginia.We are running 28 bravo 1 and it helped out a bit.We are going try spinning out to see if it helps out on the top end.Thanks for the info.
Wil
Wil
divenstar
10-03-2008 07:48 AM
Payton
Drives and Lower Units
3
05-15-2007 06:08 AM
