Baja 38
Baja 38
I have repowered from 502 MAG to 496 HO and my mechanic told me I need new 4 balde props instead of the current 3 blades one.Is he correct ? and which prop should I buy?
thank you
AM
thank you
AM
Offshoreonly Advertiser
The HP range doesn't suggest you have to change.
What are you running now and what are some of the performance numbers?
[email protected]
[email protected]
The 22 Bravo 1 prop will run similar rpm to your 23 M+. Since you are only at 4900rpm with a 5150 rpm limiter, you can run either propeller with the new power and concider Lab Finishing as a option.
[email protected]
[email protected]
You should not need new props with the engine swap. They are nearly identical in HP. You might pull another 100rpms with the new engines. Bravo 1 4 blades will give you a better cruise speed and the boat will plane out easier.
