Tanks Skater...
#71
Interesting. Your diagram shows drilled and taped into the exit water side of the exhaust plate. Wouldn't you want it on the inlet water in the exhaust plate?
Just curious.
Just curious.
#72
Good question! My speculation is that it is adding back pressure to the water jacket system to provide increased water pressure?? All I know is that it really works well. I thought about the physics of it and would add that it works just opposite the popit valve that relieves pressure at high RPM.
#73
Kirk, Are you seeing differential water pressures from port to starboard engines while in high speed turns (loosing water pressure)? I was getting temp. alarms while in sharp turns at my "skinny" lake. I added a water balancing hose connecting the engines thru the adaptor plates and now have very close to equal water pressure in both! Just wondering has you experience.
Passed a lot of Yamahahas and E tecs today
