31SS swim ladder?
31SS swim ladder?
Do these models not come with a ladder?
I see there is a grab rail in the middle of the swim platform. Are you supposed to step on the tie bar and pull yourself up?
Re: 31SS swim ladder?
The placement of the ladder is crap it sits on top of the port drive almost perfect for a child to cut their foot on the blade when using the lower step. I have already had to replace mine twice because people leave it down and it hangs up on the drive just above the prop, unlike more forgiving placements in the center where it rests on the tie bar. The exhaust tips is the reason they do not mount them in the middle but there must be a ladder other than windline that will fit there.
Cass
Cass
If the ladder is mounted correctly between the drives it can drop in front of the tie bar (between the tie bar and the transome). Pull the ladder out and point it down befor telescoping out the steps. It will drop straight down in front of the tie bar.
