Spark Trouble
Re: Spark Trouble
Originally Posted by Superbabi
Mike, I forgot, how much HP you running ????
He's running with more than us for sure...
Patrick
Patrick
Re: Spark Trouble
The Motor Was Not Dynoed After The Changes . Installed New Aluminam Heads Another Carb And An Air Pump. All Small Still Fits Under The Flat Hatch. I Think The 18 Inch 3 Blade Prop Helped Alot.
Re: Spark Trouble
Didn't you lower the engine a bit when you installed the speedy?
Patrick
Patrick
Re: Spark Trouble
Yes The Motor Was Able To Go Down 1 Inch For The Proper Drive Height. With The New 10 Quart Canton Pan I Had To Install A Shortie Bildge Pump. The Shaft Is Now 1 Inch Below The Bottom . The Balance On The Boat Should Be Incredable.
