Which powerstroke diesel should I stay away when looking at fords? is it the 6.0 or ?
#41
Buy a Duramax
You can't beat the 5 year 100,000 mile warranty, 2500's will tow 17,000 off the bumper. Try that with a Ford or Dodge. The 2011 has a new chassis, much heftier design. Check one out, the best part is that the new emission systems cleaned up the exhaust so much,they don't stink to high heaven when you are behind one. Go Chevy!
#42
#43
#44
Ford vs GM
I for one am glad to have "real world comparison" in the field doing what these vehicles are initially intended for! Nothing harder on a truck than day in day out use in the field. Thanks Jassman! ..........................................Robertjr ......................
#45
To anwser your question, get with a mechanic or someone like Fixxxer that has the knowledge. The 2 6.0 we have do have over 200k , look like dog poo, we worked the crap out of them knowing we wouldnt be trading them in, and Im hoping to get another 25-50k out of them before an entire rebuild or one of the employees buys them. The Duramaxes we have are the same, they have their own PITA issues. The 6.0 got a bad rap, due to Fords early release and trusting International. International to me is a failing co in the big truck arena. The 05 have a spring set up front which makes turning way better and the majority of the issues were being handled. Ford has done a great job with their own motor..6.7.. and wish that would have started earlier. I know from our own issues torqing head studs, and a little .85 part that goes to the radiator will resolve the majority of issues. Also the 6.0 is way easier to work on per my Ford mechanics. He actually likes them better, less smog stuff. Also change your oil every 5k, rear end and tranny 25k, and keep tires rotated and follow Fords recommendation on tire pressure, cause Fords will eat up some tires. ALSO LEAVE THESE TRUCKS STOCK, NO EXHAUST, NO INTAKE, AND HELL NO.. NO PROGRAMMER.. Good Luck Jeff
oh ya. have these checked or eliminated..the 6.0s have a problem with clogged EGR and clogged oil coolers.
#46
That right there kept me from boating for 90% of this summer. I bought the truck last year, previous owner was nearly in tears seeing his baby being driven away, had every bit of paperwork for all work and mods done to the truck. I knew it had been taken care of, and all the trouble items had been replaced and improved. One of the things he told me was the ficm and programmer were custom set up together, don't mess with them, and don't let ford reflash either one. Truck ran and drove great, until I put the boat behind it. Then I had overheating issues. I spent months troubleshooting and diagnosing every system that could possibly be causing my issues without finding anything wrong. I finally was going to break down and take it to the dealer, so I took the tune off of it and just like that, all of my problems went away. I'll be driving it this way from now on. This saves me from going out and buying an '11 in the next few months. I may still buy one in spring, but now it will just be because I want to, not because I don't trust the 6.0.
#47
#48
Sandcraft is right. Stay away from the 6.0. If you want a newer truck get the 08-10 with the 6.4. That motor will make big power(500hp) with an intake manifold, an air filter and a tuner.
As to your dashboard problem, if you use a windshield shade, the dash won't crack.
stay with the 2005 and later. if you want to know warranty history send me the vin. i can run oasis and tell what has and has not been done.
dont listen to cat. he doesnt even have a truck anymore!!!! and yes, ford overall is better quality. that is why they are the most used. more trucks made... more out there... more reported problems due to more of everthing. ford is the way to go. send me pms of vin numbers you are looking at. and if under warranty... send it to me. i will take care of you and update the truck to a every day truck.
and cat... the 6.4 is a POS!
#49
CAT! never put an air filter on anything! they are crap and the 6.4 will for sure have mutiple re-ge issues and oil growth.
you need to do your homework.. diesel forums dont make an expert
#50
