Ford 6.0 turbo
ez- That's why I'm going to put a new one on it
If the amber wrench light is on, probably not the turbo.
As others mentioned. Get the code. Get a device to read the coolant temp and the oil temp after operating temperature 60mph on a flat road. Should be less than 15 degrees. If more the oil cooler is plugged.
Is the original coolant in the truck? If so, flush it a few times prior to changing oil cooler and then put Caterpillar EC1 coolant in it with a coolant filter.
yes, coolant has not been changed, original
all I can say is not driving the truck everyday leads to killing turbos they have a issue...I do not drive my duramax much at all, sits in garage until we need to tow usually, no turbo issues, sounds like some high paid engineer screwed up...
