2004 37 Avh
Old 11-05-2006 | 09:53 AM
blaniac's Avatar
Default Re: 2004 37 Avh
Originally Posted by Sydwayz
Pat built that boat as a "west coast special" poker run edition. The boat made a few media appearances, and I believe the owner is a SCOPE member. I talked to Clark (crb76) about the boat last night. He said the boat is in immaculate condition. There is also a video of that boat running on the Active Thunder website. Look at the bottom of the Active Owners page.
AT prefers not to install ITS on the 37AVH, as the boat just does not need the setback. The props are already in clean water due to the dramatic step and hull design. A couple boats have had setback boxes installed (Stelling), and the boat just does not need them.
The aesthetic advantage of the ITS is a less populated transom, over the Marine Machine steering that is normally installed. OverActive, which is currently being built by ActiveShack here on OSO decided with Pat to go with MM steering over ITS simply because the boat already performs perfectly with that setup.
That boat in CA is a great boat at a great buy. Snatch it up.
Okay, so the 37' does not NEED the setback afforded by the ITS system but does or could it be of ANY benefit ??
blaniac is offline
Old 11-05-2006 | 10:34 AM
crb76's Avatar
Ascetically yes......Performance is TBD. Someone will have to build one. I was going to build one.
crb76 is offline
buggyride
09-16-2007 05:19 PM
289FIA
28
11-15-2005 09:16 PM
bshzba
Active Thunder
1
10-17-2004 11:06 AM
Chris
Active Thunder
3
09-13-2003 08:19 AM
