Hydromotive On 25 At
454 mag carb with 1.36 drive.23 mirage plus thats the fastest prop i have but boat porposies alot.25 mirage plus worked alittle but can only pull 4500 rpm.23 revolution 4 blade but only 4600 rpm,24 b1 same only 45-4600 rpm and now this 23 hydro.the boat rides and handles better with the four blade.may try a 22 b1 or switch drives to 1.50.gonna get into the motor this winter for a 500 hp upgrade.thanks guys
Don't need anymore on a shelf collecting dust. I Give them a call after i fix a brand new BG carb that crapped out on me yesterday
Thanks. What did you not like about the prop?
it handled very well but only pulled 45-4600 rpm.should be 5000 but also spinning a 1.36 drive.my friend is got a wedding this weekend so i will try his 1.50 drive and some other props to see if i should switch drives.
Im sure youll enjoy yourself much more with out me out in front of you, only thing to worry about this weekend is that pesky 25 AT with the 540! Just come out Friday night and stop fussing about the dam thing and drive it.
