porpoise
Old 09-07-2008 | 10:07 PM
  #41
Talking Bravo vs. Hydro
Ok, everybody's ears are open. Let's hear a little more about the Hydros...
In my case, needing stern lift, the Hydros outperform the Bravo's, hands down. Turning out 26"p 15"d QIV; labbed & re-pitched to 26.5, diameter shave to 14-5/8 by Throttle-Up....
spilman is offline
Old 09-07-2008 | 10:17 PM
  #42
BTW, they provide enough lift to require 1-1/2" drive spacers...
spilman is offline
Old 09-08-2008 | 10:12 AM
  #43
i am not sure if i need stern lift or not i cannot get the boat to layout when i am wide open.
aabaroni is offline
Old 09-08-2008 | 10:33 AM
  #44
slboatdrinks's Avatar
What do mean by "layout"?
slboatdrinks is offline
Old 09-08-2008 | 12:05 PM
  #45
when i am wide open the boat wants to hope around and you have to get out of the throttle.
aabaroni is offline
Old 09-08-2008 | 12:37 PM
  #46
On flat water and trimmed out to 6 or 7ish, the boat will tend to hop at WOT. If it's dead calm with no wind, it won't happen
I have eased the trim back down, (in) and pulled back on the throttles slightly to limit the hop. Once it's settles down you can throttle up and trim out again.
I don't usually boat in flat calm water. The boat shines in the rough stuff and will take all the throttle you can give her.
I was averaging 75mph in 2 to 4 foot seas and could have easliy been doing 80plus.
Hope this helps.
Steve
Old 09-08-2008 | 01:12 PM
  #47
i have no problem at 75. where do you run your trim and tabs at 90?
aabaroni is offline
Old 09-08-2008 | 01:18 PM
  #48
To hit 90 plus in calm you need trim up to 9, no tabs.
Running in 2 to 4's my trim is set at 5 1/2 to 6, again, no tabs.
The only time I drop a tab down is when the wind is pushing me over hard to one side.
In my experience, running the tabs at any other time will upset the hull and ride.
Old 09-08-2008 | 01:37 PM
  #49
thats what i wanted to know. i was running trim 7-8 at 90 but the boat still is jumping around i am going to try to trim up some more. thanks
aabaroni is offline
Old 09-09-2008 | 08:26 AM
  #50
R Addiction's Avatar
AT Cult Member #3
And a full tank of fuel and throw four grown men and a glassy back rivah in Virginia......90+ til we ran out of room!! One of the coolest runs in flat water I've ever done!!
R Addiction is offline
