Additional Power Steering Pump >
Old 04-21-2009 | 09:26 AM
Default Additional Power Steering Pump
I currently have one power steering pump on one motor in my 1994 32' AT. I would like to put an additional working pump on the second motor, for those unexpected times a motor goes down during operation. How do I go about this and do I need any special hardware? I have seen photos of pumps on both motors that appear to be connected and both fully functional at all times. Any tips or ideas would be helpful!!
Offshore Drilling is offline
Old 04-22-2009 | 01:38 AM
I would post this the the Tech Q & A section. I remember it being discussed before, but don't recall specifics.
Griff is offline
Old 04-22-2009 | 02:53 AM
c_deezy's Avatar
CP has a kit that will do it...for about 400 bucks. You should be able to find some info in a search. Seems to me you should be able to put one-way valve on the pressure side, tee it together before the char-lynn valve and then have a common return reservoir that serves as overflow to both pumps.
Planning on doing this to a boat before too long as well, but plan to shop around and should be able to piece the parts together for less than 4 hundo.
http://www.cpperformance.com/detail.aspx?ID=5095
c_deezy is offline
Old 04-22-2009 | 02:59 PM
Thanks for the advice I'll check out CP.
