-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   525 CMI Header Issues? (https://www.offshoreonly.com/forums/active-thunder/219652-525-cmi-header-issues.html)
dennis1009 11-06-2009 09:46 AM
What years were these problems? What was done to correct the problem?
t500hps 11-06-2009 10:20 AM
all years.......don't use is the only way to avoid issues!!! :) They all leak eventually, very quickly in salt water!!!
crb76 11-06-2009 11:12 AM
Pull them and send them to CMI at about 200 hours. The refirb cost is better than the alternitive. They cost $150 a pair to refirb at CMI plus shipping.
Gladhe8er 11-06-2009 11:16 AM
I have about 140 hours on mine...no problems, knock on wood. My brother has had all sorts of problems with the headers leaking, but has at least twice teh amount of hours.
BillR 11-07-2009 06:45 AM
2 Attachment(s)
One way to help assure no problems is to install drains. These will drain header to an overboard dump so no water remains in header while not being used.
Yes water will flow while motor is running, but negligible on cooling ability.
This WILL make your headers last MUCH longer. Also, do not use 90 degree fitting as shown or aluminum. I am pretty sure the 525's have the ends (towards stern) on the water feed tube already threaded. You'll need an adapter to (std size) to go from what is already tapped into header drain to bring it down to #8 or #10 AN.
Eddie Marine has SS overboard dumps. Easy to install, and works!
dennis1009 11-07-2009 09:14 AM
Great Idea. Someone should make a kit for this modification.
REMEDY 11-07-2009 08:28 PM
Is it ok to leave the pink antifreeze in them after winterizing? Or drain that out too.
Macklin 11-08-2009 07:29 AM
After all I've read on this issue...drain em!
And yes, the 525's do have the threads on both ends. Great post Bill.
outriggers 11-08-2009 07:48 AM
There is a factory mod to remove the bypass hoses and drill the top fitting on the Stb. side. More water goes though the headers. I think it keeps the headers cooler making the the heating and cooling cycles not as extreme. The letter I have says #OM956327 and up. Doug
dennis1009 11-09-2009 06:46 PM
Do you have any more info on this? Where can I find out how to do this? Thanks.
