Remedy to fix OCD! >
Remedy to fix OCD!
Remedy to fix OCD!
Old 05-07-2011 | 07:44 AM
camptappakeg69's Avatar
Sweet, fly up here next.........
My to do list....
Take front trim off & and send to sleevles, install new wind deflector
Finish taking seat frames & upper grab handles apart to paint
reassemble side bolsters & sunpad.NO more pink&purple
dewinterize, oil & gear lube change
impeller
Complete wash, buff & wax
Finish new bunks for hoist
Wow I better stop pushin these buttons and go get the boat
camptappakeg69 is offline
Old 05-08-2011 | 06:01 PM
OCDACTIVE's Avatar
A.T. Cult Member #4
Remedy made use of some equipment not usually used on a boat (for mechanical purposes that is) to get the impeller in place. They don't call him the flying magical mechanic for nothin! Thanks again buddy!
www.sbonh.org
OCDACTIVE is offline
Old 05-08-2011 | 06:37 PM
ACTIVESHACK's Avatar
I hope you didn't put that in with those bottom blades like that
ACTIVESHACK is offline
Old 05-08-2011 | 06:43 PM
OCDACTIVE's Avatar
A.T. Cult Member #4
He spun it so they all are going in the same direction. No worries... Also started her up and it is working perfectly.
www.sbonh.org
Old 05-08-2011 | 08:42 PM
R Addiction's Avatar
AT Cult Member #3
Ok.....was that some sort of "personal" lubricant Scott? Not sure I want to know where that came from!
R Addiction is offline
Old 05-08-2011 | 08:50 PM
slboatdrinks's Avatar
"Bobber juice"?????
slboatdrinks is offline
Old 05-08-2011 | 09:18 PM
REMEDY's Avatar
Don't get him all worked up Shack... he will be takin it off to see if they are still like that!!!
It doesn't matter how it goes in... just slide it on the shaft and give the pump a spin before bolting it up. I showed him all that in case he ever has to change one on the water. Especially with only one engine! I usually use 3m silicon paste, it won't eat the rubber if you are not gonna start it right away, but I think the wet worked better!! Slid right in.
OCD is coming along as a boat owner!!
REMEDY is offline
Old 05-08-2011 | 09:25 PM
REMEDY's Avatar
He assured me it was a new unused bottle as I was giving him the your kidding look!!
REMEDY is offline
Old 05-09-2011 | 07:59 AM
ActiveThunder's Avatar
Ok, let me get this straight. You keep a bottle of lube in your toolbox? And this is for changing impellors?
I'm not buying it.
I'm thinking we need a moderator to clean this thread up.
ActiveThunder is offline
Old 05-09-2011 | 08:07 AM
OCDACTIVE's Avatar
A.T. Cult Member #4
It wasn't in the boat.. nor my tool box.... He asked for something that was non-corrosive that would work...
I may keep it on board now and in my toolbox just for a laugh.
www.sbonh.org
