Drive tie bar setup >
Drive tie bar setup
Drive tie bar setup
Old 03-10-2012 | 11:12 AM
Default Drive tie bar setup
Ok, measured my drives and found that they are set up with the props closer than the front of the drives \ / . Though my props turn out. Is this right? I could see a theory that the props push in going forward?? Any thoughts fellow cult peeps?
abmotorman is offline
Old 03-10-2012 | 05:53 PM
Just checked mine...1/16" toe in at the front. What is recommended?
mobuzz is offline
Old 03-10-2012 | 07:18 PM
To me what you have would be correct for a "turn out" application. I adjusted mine as perfect as they could be. As long as some fat as* doesn't stand on my tie bar I should be good.
Old 03-10-2012 | 07:19 PM
If Props are turning out 1/16 - 1/8 toe in so the prop torque will pull them straight at speed . If I remeber correctly, bunch of past threads on it in here.
laszlo01 is offline
