Replacing foam on engine hatch question
Anybody replace their foam on the engine hatch? Mine is settled and causing a low spot in the middle of the hatch. It looks like the large Philips head screws around the perimeter hold the cushion/plywood? Is there more screws under the mirror? Thanks
Correct. Just the screws you see. And what you are seeing is the foam on the top side of the "box" of the hatch. Once you pop it off you can replace the foam.
