New motor for the Tantrum >
Old 11-04-2012 | 09:37 AM
R Addiction's Avatar
AT Cult Member #3
Originally Posted by My Addiction
c'mon I was doin 77 with around 500 hp. The 600 Tantrums are doing 85. Did Rob ever have his motor dynoed?
Nick, what do you think mine will do with 530HP (crankshaft)?
Does your Ext. box make that much of a difference?
R Addiction is offline
Old 11-04-2012 | 10:17 AM
Its finally done. Still needs paint. We dynoed it yesterday and made 693hp at 5500 rpm through 5700 rpm, 733 tq at 4500 rpm.
Its a 555ci gen. 4, bowtie tall deck roller motor. Merlin 320 iron heads w/ little work, 1050 dominator, 9.6-1 comp. ratio, 26* timing on 93 pump gas.
I would hazard a guess thats without accesories or marine exhaust?
HTRDLNCN is offline
Old 11-04-2012 | 10:38 AM
He did, but the 572 made a lot of torque and peak hp wasn't real high. Anything over 5300 rpm could guarantee the drive was broken. I believe he had a 32p bravo 1 labbed and was on the limiter with ease. It should definitely be faster than what I was saying just busting chops. Glad to see some good power back in that hull!
Unlimited jd is offline
Old 11-04-2012 | 10:41 AM
The x dimension in his boat is a lot higher than most of the others. If you have a standard build boat I believe you're drive would end up to deep and slow the boat down. Iirc his even had a 1.5" spacer in the drive even though the box allows for higher drive height.
Old 11-04-2012 | 06:04 PM
Ike's Avatar
Ike
Charter Member#93
50? maybe
Gellner Engineering 1025"s
Ike is offline
Old 11-04-2012 | 08:19 PM
hopefully high 70's maybe 80, not sure. The box, I have been told is good for 1-2 mph but makes it handle way differently.
My Addiction is offline
Old 11-04-2012 | 08:29 PM
I have the KE cast aluminum long headers, so I dont think I am going to loose much there and with all that torque....accesories. I know the number will be different once installed and hooked up and spinning a prop, but at least I wont be playing the guessing game when trying to prop it to the right rpm. That was my main reason for dyno testing.
Old 11-04-2012 | 08:36 PM
Originally Posted by lil red
Awesome! If I may ask why so little timing? Did you check egts? Don't want to see any valves tulip.
Timing. we started out at 22* and autolite 23 plug and only made 650. then went to a colder NGK plug and 26* then made the 693. Then 29* didn't show any improvement as stated before.
Old 11-05-2012 | 08:24 PM
Talking
Bad ass dude.. Thats some TQ for a Bravo.. I have an XR upper for sale
ICDEDPPL is offline
Old 11-06-2012 | 05:48 AM
REMEDY's Avatar
Just curious.... do you have any fuel flow numbers on your dyno sheet?
REMEDY is offline
