1996 compared 1998 25 at >
Old 06-15-2013 | 11:36 AM
Default 1996 compared 1998 25 at
what is the differnce between 1996 25 active thunder and 1998 I know 1998 is called tantrum, is the bottom the same as 1996 ,thanks bob
sullynory is offline
Old 06-15-2013 | 02:13 PM
classclown's Avatar
Registered User
No wood in 98 and it's a few lbs lighter not sure about the bottom
classclown is offline
Old 06-15-2013 | 03:37 PM
i think mostly the same except no wood.
state1310 is offline
Old 05-19-2015 | 01:32 AM
What year did they cease using wood in the builds?
Trojan-man is offline
Old 05-19-2015 | 01:03 PM
Griff is offline
Old 05-21-2015 | 01:33 PM
Bottom is identical and so is the top deck. In 1998 AT used Mantex (high density PVC foam) for transoms, stringers & bulkheads. Cabins in both years were stick built with a small fiberglass galley/sink/storage to port. Great rough water V bottom..handles snotty water alot better than many boats that are much bigger!
JUPITER PULSARE is offline
