-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Sommer 2015 has begun... (https://www.offshoreonly.com/forums/active-thunder/325381-sommer-2015-has-begun.html)
sommerfliesby 04-21-2015 07:00 AM
3 Attachment(s)
Hit the Big Pond on Saturday...46 degrees out! Pat...that is like 1/2 the temperature you are used to! Your Miller Lite probably isn't even that cold! Boat ran great...freshened 525s courtesy of teamsynergy. New valve springs, retainers, gaskets, and a new set of rockers in one motor (found a cracked bearing on one, so bought a whole new set of Teagues). Oh...also...some welded up CMIs...when we pulled them, we found pinholes on three of the four (only one was questionably serious, as it was by the collector). Got them patched up and pressure tested...and good to go.
Rolling down to the swamp next Wednesday for the Tickfaw Two Hunnert! Gotta get her shined up!
jmeng 04-21-2015 10:25 AM
Hopefully we run across you somewhere on the 200, been waiting years to see a late model 37 AT in person.
sommerfliesby 04-21-2015 11:01 AM
Oh...I'm guessing there is a high likelihood we will be in the Sun Buns neighborhood on Friday for the bikini contest...lol.
We will be running with Craig and Patti again...following them around, anyway.
jmeng 04-21-2015 03:27 PM
Yeah, I'm hoping to make it over there Friday also. Drive safe coming down.
Pwraddr 04-21-2015 05:35 PM
have fun, boat looks great, glad you got her tuned up!
F-2 Speedy 04-21-2015 05:46 PM
Nice hot rod Sommer, wish I could join ya, mines in the shop getting a Heart transplant, in the capable surgical hands of the father & son duo in Broken Arrow, OK
bigboat28 04-21-2015 08:52 PM
Rolling down to the swamp next Wednesday for the Tickfaw Two Hunnert! Gotta get her shined up![/QUOTE]
I am sure it is probably spotless now, lol.
sommerfliesby 04-22-2015 06:37 AM
You got it! Spent 5 hours on it over the past two days...even waxed the underside of the engine hatch. :)
Gladhe8er 04-22-2015 07:54 AM
Be careful with those headers. Once they crack, they only keep cracking. Mine cracked 3 years in a row causing two new top ends and a lot of downtime. Got Stainless Marine headers on there now and have had 2 years of trouble free boating.
sommerfliesby 04-22-2015 08:01 AM
They weren't cracked anywhere...just rusted with pinhole leaks.
jbraun2828 04-22-2015 08:15 AM
Make sure you check your tail pipes as well. Mine were cracked and getting new top end right now.
Gladhe8er 04-22-2015 08:25 AM
Still watch them. That's how they start to go. How many hours on the motors?
sommerfliesby 04-22-2015 11:26 AM
350 or a little more...but a good 280 of them were in salt...
Gladhe8er 04-22-2015 02:34 PM
Yikes. I popped mine at 180, 200 and 220 hours. If you see any abnormal steam or feel any hesitation getting on plane - pressure test those bad boys.
