My old Sonic used to like to collect water in the forward compartment. I had considered getting some goldfish, but after sealing up the bow light {common problem with that vintage Sonic } all was good! I know unrelated, but funny, none the less!
Originally Posted by 509 SC
(Post 4462329)
Originally Posted by Pwraddr
(Post 4462319)
All the white silicone was from someone that tried to seal the hose on the wrong sized drain.
The new drain isn't as small as the original but at least now it is all sized correctly and can flow the amount of water without backing up. [ATTACH=CONFIG]557509[/ATTACH] [ATTACH=CONFIG]557510[/ATTACH] [ATTACH=CONFIG]557511[/ATTACH] [ATTACH=CONFIG]557512[/ATTACH] I figured out that the size of the drain hose/cup was probably too small...and the problem was compounded by the HUGE amounts of water running off the roof. Towing home in the rain last weekend...I found my other problem was accurately diagnosed as leakage from the mushroom cleat. Gonna have to get in there with a big silicon solution...but for now...a towel will do! |
Originally Posted by sommerfliesby
(Post 4462442)
(Post 4462319)
The new drain isn't as small as the original but at least now it is all sized correctly and can flow the amount of water without backing up. [ATTACH=CONFIG]557509[/ATTACH] [ATTACH=CONFIG]557510[/ATTACH] [ATTACH=CONFIG]557511[/ATTACH] [ATTACH=CONFIG]557512[/ATTACH] |
Originally Posted by Sydwayz
(Post 4462689)
Just be sure that there is no way your bow stop is going to catch that drain protruding from the hull; especially when at a ramp that has different angles an attributes than you normally encounter.
| All times are GMT -5. The time now is 10:01 PM. |
