Thunder EnLightening's Comin' to Life >
Old 12-04-2002 | 07:47 PM
Default Thunder EnLightening's Comin' to Life
Talked with Pat this evening and he has been doing a little magic on TE. He put some Labbed 30's on it today and hit the rev limiters. And the best part was the boat was going 82 mph. Not sure how much is left but looks like a set of labbed 32's may be the ticket.
Oh.....and for those on the Thunder Run, I understand the throttles are fixed
H2OWarrior is smillin' tonight
h2owarrior is offline
Old 12-05-2002 | 05:27 AM
MassiveThunder's Avatar
Told you that he would make it run!!!
MassiveThunder is offline
Old 12-05-2002 | 07:45 AM
Jassman's Avatar
A is better than a but when Pat gets done dialing it in you will be going I told you it would do 82-84, I am happy for you guys, this next Key West run is going to be a blast
Jassman is offline
Old 12-05-2002 | 08:55 AM
ToddW's Avatar
Excellent !!!
ToddW is offline
Old 12-05-2002 | 10:33 AM
Registered User
I'm really glad to here the numbers are up. Some times it takes a little while to find the sweeeet spot. congrats!
Obnoxious
ObnoxiousThundr is offline
Old 12-05-2002 | 11:17 AM
MrsAttAdj
Smile
That is great news!
Oh and... H20... FROM those on the Thunder Run... whew... we are so glad your throttles are fixed!!! Looks like we won't have to be sending you "Get Well" cards after that carpal tunnel surgery after all!!!
Old 12-06-2002 | 07:14 AM
Wild Horses
Just to note, when we were discussing motor options with Steve and Pat, we were assured that an AVH with 500 EFI's would run 88 mph. Hummm! Good numbers all the same though.
Trevor
Old 12-07-2002 | 08:14 AM
Wild Horses, I think a 37 AVH with 500's can run 88. My boat is very heavy. It has corian counter tops, A/C, hot water heater, a 4kw diesel genset etc. It should run 84 when Pat gets her dialed in completely. It also has XR drives which rob a few more mph. Pat is going to try some standard Bravos to set a new base line.
The boats are fast.
Old 12-07-2002 | 11:30 AM
ROUGHSTUFF
I spoke with Pat yesterday and he said the boat Whatever which is fully loaded including genset ran 76MPH right out of the box with 496 HO's. There were five people on board and a full tank of gas. This was with prop's that weren't labbed finished and usually you will pickup a MPH or two when the motors loosen up.
Not to shabby!
JCPERF
02-21-2007 07:03 PM
Back4More
Fountain
10
07-21-2005 08:12 PM
BLee
04-21-2004 09:15 AM
mopower
03-01-2004 07:23 PM
Offshore Addiction
01-13-2003 10:57 AM
