-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   37avh speeds ? (https://www.offshoreonly.com/forums/active-thunder/63899-37avh-speeds.html)
26sonic 11-16-2003 09:09 PM
37avh speeds ?
what speeds can be expected with the 496 ho's and 500 efi's and 525 efi's ?
h2owarrior 11-16-2003 11:08 PM
I had a 2002 37 AVH with the Mellinuim cabin and all the goodies including a genset, A/C with heat, hot water heater, microwave, corian countertop, etc......it was loaded.
With 500 EFI's, 1.5:1 XR drives and stock 32p Bravos the boat would run 76-79 at 4500-4600 RPM depending on load, fuel etc. I am sure the boat had more left in it. With a set of labbed 31p the boat should run low to mid 80's. The way it was set up was great for cruising. I could run 60 mph at 3500 rpm. Very fuel efficient.
Are you looking at buying or building a boat? Give me a call if your interested in talking about the boats.
Kevin
(309) 494-1046.
excursion 11-17-2003 07:36 AM
I have a 2002 AVH the cabin is not as loaded as Kevins but nice eqiupped, I have HP500 carbs, and 30p props, and with about 1/2 tank ran 85.2 and with almost empty tank cool air and 6 inch chop ran 86.4, I was really suprised to see those numbers, I hadthese motors in a 32 AT and could only see 82 once on a good day.
ToddW 11-17-2003 10:03 AM
Our 2003 AVH with 496HOs has hit a top speed of 75mph. The boat typically runs 72-73mph.
Oh, by the way, it is for sale.
Todd
Thunder Roy 11-17-2003 12:42 PM
I HAD A 2000 37AVH WITH 500EFI'S AND STAND OFF BOXES. RAN 88.4 ON GPS
JAIME STAR 11-17-2003 04:19 PM
TODD W. OUT OF CURIOSITY, WHAT ARE YOU THINKING ABOUT GETTING WHEN YOU SELL THE MONSOON?
h2owarrior 11-17-2003 10:46 PM
Wow:eek: You have got to be pleased with those speeds:D :D What is the RPM of the motors at that speed ? Is there any left ? Not that you would really need anymore out of a 37 foot boat running in the high 80's with 500's.
That hull is incredible isn't it:D :D :D
excursion 11-18-2003 07:00 AM
Yes, I was really happy with the way it turned out. Everyone had told me that it would see mid eighty's,but you know the way that everyone stretchs the speed by a couple mph ( industry wide). The props are stock bravo 30's, with the rpm on the rev limiters, some time I have to just trim in just a little and it falls right on 5500rpm. I know this is a little high for these motors but just had about 3-4 weeks with the boat before it got cold here. I am sending the props off to get worked to 31p, but I am a little comprehensive because I don't want to mess up what I have now.
The hull is the best I have ever ridden in, one test ride and anyone would be sold on the boat. My girlfriend did not like the 32v at 80mph, but the 37 doesn't bother her.
ToddW 11-18-2003 09:45 AM
Jaime,
A custom built motorhome :)
ToddW 11-24-2003 08:13 AM
Just got back from a cold weekend in Havasu. There was wind advisories as well. We thought it was a good time to go boating. We had the lake to ourselves.
The boat ran its fatest at 77.2 mph. Awesome.
