Fastest Advantage Boat !!!!
#31
Well, Fired up the new motor today,.....Opps, I jizzed in my pants!! Sounds great, every thing is working good, will go out for a water test on Sat. Suposed to get up to 54 deg. I think I,m going to need to buy antifreeze by the 55 gal drum!!! We'll see how she runs, save up some$$$, Going to go with the box, -2, Hydro steering all at once, come spring.
#32
I talked with Scott at Advantage last week and he definitely recommended the shorty but said from their experimenting, they didn't pick up any mph with a box. So, I am looking for a -3 now ad hydro steering. I did get 67 mph at Havasu with a labbed 26p. Think I had enough power to run a 28. 70... here we come!
#34
-Tom
#35
Tror, what do you have for air into the engine?
Not for sure, and not saying anything bad, but Advantage has always lacked air into the bilge!
I really changed my performance when I added the scoops. Not saying that is the way for you to go.
Just saying when I first brought mine home I had a hard time with numbers, after many tests and runs I cracked the hatch just a touch and gained over 300rpm! Really could tell the response @ wot.
The following spring I had the hatch scoops done @ Advantage.
Next time out, just bump the hatch open an inch or so. BECAREFUL! not to go too much and have a blow off!!!!!!
This Cat is trying to keep up with the Big Dogs
#36
#37
Couple of things: 28 has plenty of air it's a single engine with a very large bilge area. It has fresh air at each beam plus air vents and Pockets when the hatch is closed. Let's close the air issue. My 28 ran a summer with a 1200 hp plant. It takes a huge amount of power to sled a 23 dead rise boat through water. Thor is correct, boxes will gain u a bit of speed because you create more overall bow lift with less hull in the water. But more importantly, the boxes will stabilize that Victory at 80. Have you had that so called flat bottom to 80. 23 degrees is pretty flat. 80 is a handfull at 80. Yes guys will boast I blasted mine to oblivion, but hit a roller at 80 in a 28! After cleaning up the mess from a bowl loss, you'll thank the lake god for not calling your number. Put the boxes on, raise the drive and hand on. 32 & 34 are twin engines. Totally different beast to a fairly light 28. And a moon diff from a cat. Steering and boxes! Or enjoy the fun 28 and crank it up with a 32 or 34.
#38
#39
335 CNC. 117 cc. 8.5-1 CR
Crowed billet rods. Callie's blower crank
JE pistons
Blower shop 10-71
Whipple MOAC IC
Dry sump. Canton pan
CMI big tops
Mercury ITS
Imco SCX. 34 5-blade
Cam Motion cam .670-.670 250-260 dur
T&D shafts.
1170 HP 12 PSI 960 TQ. 6300 RPM 110 gas
1001 HP 9 PSI 910 TQ. 5900 RPM 93 gas
MSD EFI ingenious software. 80 lb injectors
Twin FAST air only tb's
