Go Back  Offshoreonly.com > Owners Forum > American Offshore
Prop shaft height. >
Prop shaft height.
Prop shaft height.
Old 10-22-2005 | 12:58 PM
Banana Split's Avatar
Default Prop shaft height.
What is the best prop shaft height on a 26 AO?
Its 2 1\2 inches below the center pod now.
Thanks,Dave
Banana Split is offline
Old 10-23-2005 | 11:23 PM
Re: Prop shaft height.
1 inch to 1.5 inches below works good
quest is offline
Old 10-24-2005 | 04:27 PM
Default Re: Prop shaft height.
Quest thanks for the info. Im gonna try a 2 inch shortie ill let you know how it turns out.
Dave.
Old 10-26-2005 | 11:00 PM
this could be a good candidate for a maximus 5 blade after you install the shorty drive to get max top speed... especially if the prop slip goes up much...
Don
chromecat is offline
Old 10-28-2005 | 01:00 PM
Thanks,Dave
Mind if I ask how and what do you measure to find this out? And how easy and what is required to change it?
Thanks.
CA_Southpaw is offline
Old 10-28-2005 | 03:21 PM
draw a line on your drive even with the center of the propshaft, then when that line is parrallel with the bottom of the boat measure the distance between the prop shaft center and the bottom of the boat. drive spacers can give a deeper "x", and shorter drives can give a higher "x"
Banana Split
0
10-22-2005 01:10 PM
michaelcaine
3
09-03-2005 09:48 PM
Attack
Fountain
22
03-04-2005 12:30 PM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
