Whipple On A Efi 500 Nsx
#32
Re: Whipple On A Efi 500 Nsx
slip was 12% to 14% using bravo pitch -1. ie 30 bravo is only a normal 29 pitch. using straight bravo pitch it was 16%. The center line of prop shaft was 1.5 inches below bottom of centerpod. Just for your info with the 3100 it is 12 % using bravo -1. and with the herrings it is 9% using the Herring published pitch.
#33
To Get That Drive Height I Will Need A -1 Shorty With
A 1/2 Spacer.i Will Get Bill To Order It Tomorrow With 1.35 Gears....
Do You Still Have Some Custom Props To Try With This Gear?
The 1.27 Gear Is Too Lazy For Me
#36
Update
Got My Imco Standard Length Lower Today
1.34 Gear The Only Prop I Had To Try Was 4 Blade 34 Bravo
11% Slip
Will Order A 32 Bravo Or Herring Tomorrow And Make Some Speed Posts
11% Slip
