prop options
Old 06-01-2010 | 08:11 AM
Ran-Dom 32's Avatar
moving to a -2 lower you have lost some leverage to carry the bow, I went through this with my boat, this can be corrected with prop tweaking
Ran-Dom 32 is offline
Old 06-01-2010 | 08:23 PM
Originally Posted by mike tkach
i have stellings boxes on mine,i cruise at 70 with no porpusing,it will hop a little between 70 to 90,above 90,its as smooth as silk,right now i have a pair of 5 blade maximus,30p,but i need more prop,looking for bravo1 34 p or 32 p to try,anybody near chicago with a pair that i can try.
Bring it up Mike, you're welcome to try my labbed 32s
AO31 is offline
Old 06-01-2010 | 09:12 PM
that would be great,where do you run your boat?
mike tkach is offline
Old 06-02-2010 | 09:18 PM
Mostly on the Chain
AO31 is offline
Old 06-14-2010 | 11:46 PM
Default so what was the conclusion on set up??
what are the thoughts of -2 x with ITS system set back 7 inches? What props would you guys all suggest and why?
I have had 5 3100's ranging in power btwn them all. Most all of the boats porpoise between 75 and 90mph then work through it to a smooth run. I have not tried merc ITS and -2 all in one package so don't know what to expect? I am also going to move the motors 12 inches forward (or is at least the plan) with only about 600hp to 650hp a piece.
Thoughts or experiences on this?
Thanks in advance!
mountaincat is offline
Old 06-16-2010 | 08:55 AM
Thanks in advance!
If you have not purchased your Merc ITS transoms yet, look on the OSO classified. Bob Leach is selling some for a smoking deal. I was thinking of going that route, and the best price BAM quoted me was 9995.00 Add to that the 5" Ziegler extension box (pricey piece) and you have a small investment in your outdrives. I am already committed to go with the IMCO boxes and use my existing Bravo transoms and IMCO steering system-----------but, if I wasn't, I would jump on the ITS system and sell my bravo transoms and IMCO steering system.
ROTAX454 is offline
Old 06-20-2010 | 12:02 AM
Thanks for the input ROTAX.......... appreciate the help, but I had already found my xr's with ITS drives. Turns out I am not going to move the motors forward, but am looking at -1 or -2 shorty lowers and am hoping to hear more thoughts from people on my scenario!
I also don't know which prop setup to go with. I have always had success with the bravo props and never tried the 5 blade. Thought on this?
Thanks a ton....
Old 06-21-2010 | 10:06 AM
tssteph's Avatar
whats the set back on a ITS setup compared to a normal bravo setup?
tssteph is offline
Old 06-21-2010 | 11:52 AM
It is around seven inches back and it contains the external steering.
bobkatz is offline
Old 06-21-2010 | 05:50 PM
Thanks a ton....
The only thing I can add to your great set-up is:
1) Add the 5" spacer
http://www.cpperformance.com/p-12356...pacer-kit.aspx
2) Add the -2" IMCO lowers
After that, suggest you call Brett at BBLADES and enlist his expertise in which prop to use and how it should be "tuned".
Randy, chime-in and help this ladd out. You have more on the water experience in this area.
ROTAX454 is offline
