How would a real windshield look on a 3100?
no designs yet,waiting for interior to finish up than i gotta take to shop for them to see it. i did stop in toledo when i was bringing my boat home a few weeks ago and had it looked at and the guy at allied plastics idea was to form the bottom to the inside angle and cold form the sheild back towards cockpit than add a forward facing lip to the top to direct more air flow away from face. the sheild would run to the outside edges and round off like nor-tech does on their cats. from the peak of the fairing the height would be only 8" above,that way i could still see over it or duck behind. but i sit lower in the boat im guessing than those of you that use stand up bolsters vs. my sit down buckets?
FF another question is how far back along the sides would you want to go? I think a nice light taper from the front to at least halfway between the front bolsters and the bench would work.
Also what material? Is Lexan difficult to keep clear and clean?
Sounds like the Allied Plastics guy may have it figured out. I knew from the angle of the fairing that it was gonna be hard to get one to look right AND keep the wind off as well.
Polycarbonate (lexan) is available with a scratch resistant coating. You are correct. It is soft and scratches easily (without the coating). As far as visual clarity, I have no expertise in that area.
well the guy from allied had no wrap on it,just rounding outside edge. i'm taking it to solas plastics to get his ideas next week,and he's alot closer than toledo. but yes lexan was the material,coated and to clean it you only use pure carnuba wax. thats it. same as all your motorcycle windsheilds and all the harley guys told my nothing but carnuba. and they've gone years without scratching theirs? but i'd like it to have a slight taper to the rear.
I just had the idea of laying a 2' or 4' metal straight-edge ruler on the fairing(with something underneath it to not scratch the paint)and have somebody raise it to where you want it while you're sitting in the bolster. Then the windscreen shop will know how tall to make it.
"...but i sit lower in the boat im guessing than those of you that use stand up bolsters vs. my sit down buckets?" felinefrenzy
3100 is a sitdown boat. I've never seen one with standup bolsters.
