28 Brave OSO Project
#191
Crazy Energy
#197
Bilge looks great!
How did you like sanding all the woven roving to accept the paint? I thought about doing mine and that's what turned me off... I figured the only way to do it properly was to sand flat the woven layer or have it lightly sand blasted or maybe rubbed down with a scotchbrite pad..
#198
Thanks guys,
I could have spent weeks sanding the bilge, but I didn't. The instructions just want you to do a light sanding to rough up the texture. You don't need to sand all the way down to the fiberglass - or smooth out the fiberglass woven layers. I bought the "brushing awlgrip" how to DVD and they actually recommend spraying a light mist of black spray paint to use as a guide. Once the spray paint is sanded off - your done sanding, the gelcoat wasn't sanded off at all - just roughed up so the paint will stick. As many people I've seen on OSO paint the bilge without sanding or prime with good results - I wasn't really worried about getting into each and every little woven groove. Plus I used two coats of primer. I really didn't have any problems getting the paint to stick. I'm still trying to get it off my hands a week later. I've tried acetone - this chit will not come off my hands. Total cost was around $400 for the bilge paint, brushes, and sand paper. I used gcm distributing - they have the badger hair brushes too http://www.gcmdistributor.com/
I saw those resto picks of Geronimo - that is what I call a restoration. You've done a hell of a job.
#199
i'm sure it will be just fine. I tend to go overboard on prep!
Looks good and best of luck. Thanks for the compliment on my project. PS, I raised the X Dimension it wasn't resto work.
Frank
You and John have alot of work to get done with little time!!
