cushioned flooring used in apaches
But it was real soft.
You may want to check w/ the current owner, who is on these boards.
Here is the stuff that actually absorbs the impact.
http://www.mitigatorinc.com/mitigator-uses/marine/
http://www.ppi-fl.com/mitigator.htm
Look up Sea Dek. It is a soft material that has a adhesive backing and you can buy in sheets in different colors. You can also have them engrave a logo or whatever you might want. I'm thinking I will use this stuff when I pull my carpet up and cut my floor to replace my fuel tank. If I had only known about this stuff a few years ago I would have redone the whole floor in my Bertram with it instead of painting it and putting a non slip additive in it.
