APACHE Scout 21 / 22 Power Options >
Old 04-23-2012 | 09:37 AM
Default APACHE Scout 21 / 22 Power Options
Need Advise…
Might be looking to power 21’ Apache Scout with New Merc 300xs.
I have a few options. I want what will be best for the boat, but also want to take resale of motor alone into consideration. I will probably only keep the boat for about 2 years and sell it. I might end up selling them separate.
Boat has Extension Box and Hyd Jack Plate, Tabs. Boat will be used in the ocean.
Options:
1st Choice:
Optimax
or
Offshore (Offshore is 700 more)
2nd Choice:
Sportmaster 1:62 or 1:75
Torquemaster 1:75
Not sure what this boat will top out at, results with similar power on other Scouts are anywhere from 75-85 mph.
extra300 is offline
Old 04-23-2012 | 12:29 PM
I would get the offshore mounting, it's a stronger mount with the trim pump located in the boat.
I would also recommend that the Torquemaster with 1.75 gears. http://www.mercuryracing.com/outboar...plications.php
As stated in the link above, the sportmaster is intended for speeds above 85. It is highly unlikely you will achieve those speeds with a 300xs.
modvp is offline
