-   Apache (https://www.offshoreonly.com/forums/apache-55/)
-   -   Apache props (https://www.offshoreonly.com/forums/apache/344760-apache-props.html)
leif 02-16-2017 01:22 PM
Apache props
Hi need some help here with the right props ..41 Apache 1987 full cabin,ssm3 standard set up,twin Bandit 510 cubic and 690 hp N/A..max 5800-6000 rpm..Im putting everything together ,what size props 16.5 x 25 four blade ?
CIG3 02-16-2017 02:33 PM
First off with SSM3 at a standard height you really will not gain anything with a 4 blade prop. If the "X" dimension is raised close to or at the surface then the 4 blade will help. I would try a 16.5-17"x28" 3 blade.
I'd get ahold of Brett at BBlades for a good idea of what to look for Phone: 920-295-4435
14 apache 02-16-2017 08:53 PM
I think a 28 is little to much for you. Boats heavy. I have #3 props in the swap 3 blade 16x28 will let go cheap they are short hub props. They may not be rite for you but may be something to give you an idea. And would work for a spare set.
kvogt 02-17-2017 07:36 AM
16x25 or 16x26 4 blade would be my guess.
leif 02-17-2017 07:54 AM
HI i bought 16,5 x 25 in 4 blade..one of the other Guys is running 16,5 x 26 with a little less power..
johnmiffco 02-17-2017 03:30 PM
there is a pair of 17x26 3 blade # 3 props on ebay
800.00
if interested type in cleaver propellers in search
cheap test props
dmaxximus 03-30-2017 10:02 AM
I have a brand new set of Merc Racing 3-blades still in box, they are big shaft though, 26 spline. 17.25 x 27 x 18 degree rake.
I'CE 04-02-2017 10:18 PM
leif unless I missed it what gear ratio in the drives
leif 04-03-2017 01:48 AM
Hi
the drives are arriving this week from the states ,but i was told 1.47..
Nate5.0 04-05-2017 09:41 AM
Buddy runs the 3 blade on his #41 and has had good luck with them. Not sure of the actual size though.
