Re: No center pod
Originally Posted by Ran-Dom 32
My brother owns this '98 26 Awesome Cat - runs triple digits - true tunnel -rides great in the rough.
Re: No center pod
Originally Posted by ROTAX454
Hey Ran-Dom, Forgot that you had told me that your brother owned a 26' Awesome. What power is he running? Still don't have my boat in the water yet. Still working on finishing the engine area and the motors. You will see mine in 06. New motors, new interior, new dash, new----------almost everything.
Re: No center pod
He runs a 800 hp blower & a B-Max drive -which he recently purchased.
Re: No center pod
rotax454... the prop is 32 pitch mirage plus @4700 rpm's .. this weekend it ran 89.7 mph. I am sending the props out and having them relieved a little to about 5000 - 5100 and see if I can get a little stern lift out of it other than that I am happy with the speed and performance. Does anyone else out there have an awesome cat with hp500's and running this kind of speed or better?
Re: No center pod
Originally Posted by RJBBC
What speed is he running with that of setup?
Re: No center pod
Re: No center pod
My mistake I was running the bravo 1 props the mirage plus doesn't work on my boat.
Re: No center pod
Ahhhhhhh. Thought that the four blade bravo would be your baseline prop. Being only generally knowledgeable about the Merc HP500, are yours stock? What is the rpm/peak HP mark? At what RPM does the torque peak? It would be interesting to see a HP/torque/RPM chart on your motor. To see where the HP and torque intersect each other. Your motor carb or EFI?
Re: No center pod
my hp 500 are stock except for gasget matching intake and heads also install marlin intake and 1050 Holley carbs. So there almost stock ha ha .the power band on hp 500 are 5250 rpm. like to see picture of your boat
Re: No center pod
| All times are GMT -5. The time now is 05:12 PM. |
