Go Back  Offshoreonly.com > Owners Forum > Awesome
why is my cat doing this???? >
Old 08-26-2011 | 11:29 AM
  #71
tssteph's Avatar
I would assume ther eare but they get pretty pricey. I moved my motors about a half inch outboard because the duel cooler bellhousing was going to hit the tunnel.
tssteph is offline
Old 08-26-2011 | 05:04 PM
  #72
Originally Posted by outlaw1
my drive line is sloping down now the trans sits about 3" above the shaft in the extension box so the driveline angle isnt a problem. its really tight for the oil pan and the water pump needs to be moved. is there a different water pump i can run instead of the stock mercury?
Do we assume that you are talking about the "Sea Water Pump"? If so, take a pic and that will help in understanding which Merc sea pump you have (there are at least two).
Again, do assume that you have a clearance issue with the sea pump?
ROTAX454 is offline
Old 01-03-2012 | 10:47 PM
  #73
Hi Cody,
I see you changed your screen name but not your phone number how about you send me the thousand you still owe me for the 4 blade props it's been years how about you make it right and I will delete the threads.
" Beware Cody White " ?
Jim
thumper038 is offline
Old 01-04-2012 | 08:21 AM
  #74
i have tried everything and my cat is still hopping unless im in 2'+ chop.
any ideas?
Thumper put a spell on your boat after you screwed him on the $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
ROCK ON !!!!!!!!!!!!!!!!!!!!!
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Old 01-04-2012 | 11:25 AM
  #75
QUOTE=cody_white83]ive decided you spend too much time on oso..haha
hey im waiting on some $$$ as soon as my money blooms i will send you some.
thanks[/QUOTE]
from 2009 in my pm box still
Hey Cody
water the tree so the dam thing will bloom
Old 01-04-2012 | 11:27 AM
  #76
Originally Posted by phil_p999
Brian, I think this is the boat.
http://www.offshoreonly.com/forums/c...-cat-info.html
It looks like he's swinging a 3 blade. That might be the problem. A four or five blade surface prop might allow more bow lift. Correct me if I'm wrong
Oh he's got 4 blades
Old 02-01-2012 | 02:27 PM
  #77
You give back those props yet
soldier4402 is offline
Old 02-07-2012 | 02:05 PM
  #78
any ideas?
cause its a piece of sh*t
phil_p999 is offline
Old 03-23-2012 | 08:06 AM
  #79
So the boat and power is not selling and he put it in the classified on OSO I have some one looking for a cat so I put him on the other Chris in the Classifieds This is how I saw it.
Karma over 1000 or just returning the props I love the support of the people on OSO
Thank you Thank you to the people on OSO
No thanks To Cody unless you make this right! Only 4 years and counting
Jim
