-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   transom problem (https://www.offshoreonly.com/forums/baja/104345-transom-problem.html)
patricklhill 05-29-2005 05:34 PM
transom problem
3 Attachment(s)
putting the boat back together after painting (graphics will come later) ran into a little problem, installing the p/s unit, I cracked the transom plate. Can I or should I try to weld it, or should it be replaced. Does anybody have a used one for sale I can buy.
Thanks,
Patrick
HRPA
outlawinil 05-30-2005 12:44 AM
Re: transom problem
I have one sitting around but it ain't gonna be red
patricklhill 05-30-2005 08:04 AM
Re: transom problem
outlawinil,
thats ok, i powder coated that one. I have some one that might be able to weld it, but he needs to look at it first. How much do you want for your if this one cant be welded.
I do powder coating on the side, so if you need any thing done give me a call
Patrick
HRPA
pwam1 05-30-2005 09:29 PM
Re: transom problem
I guess it's just me, but that is one part that I personally would not put my trust in if repaired. Go for a good part.
Need-the-Speed 05-31-2005 11:06 AM
Re: transom problem
Don't Weld. Buy A New One.
AIR TIME 06-01-2005 05:48 AM
Re: transom problem
I'll Check My Old Parts I Have A New Hp Unit On The Boat Now
