250 Es
Old 11-28-2005 | 06:39 PM
Default 250 Es
I just purchased a 1990 250 es, 454-365,Bravo drive very clean only 218 hours on boat.Any feed back on this model?Is this a true deep vee hull or is it like the current 272 model?Has anyone tried to put any power in these?I was thinking about building a HP 500.
cmckay is offline
Old 11-29-2005 | 11:45 AM
TC's Avatar
TC
Default Re: 250 Es
There are four 250/270's im my boating group. I think you will love this hull and engine combination. The boat has lots of cabin and cockpit room which makes it very functional. The hull has a 24 degree bottom that enables it to handle relatively rough water with little effort. One thing I have noticed while riding in the two boats with standard 365hp is that they seem to plow a little more than I like. I believe by using a prop with a blade profile for lifting the bow would result in a better ride and an increased top speed. The other two boats have 500hp plus and and they handle the power well.
Enjoy your new ride!!!
TC is offline
Old 11-29-2005 | 11:54 AM
Default Re: 250 Es
Do you happen to know what prop they are using on the 250 with the 365HP?Thanks
cmckay is offline
Old 11-29-2005 | 12:07 PM
JasonSmith's Avatar
Default Re: 250 Es
The 250 is the same as the 270. Nice big single engine boat. There are a few guys on here that have 270's that will run in the 80's and higher.
I would guess that the boat would do well with a 24p Bravo 1 4 blade. Most are probably running 23 or 25 3 blades.
JasonSmith is offline
Old 11-30-2005 | 10:15 AM
TC's Avatar
TC
Default Re: 250 Es
Jason is right on prop selection. I think one is running a 23 mirage and the other is using a 24 Hydromotive. I feel that both of them would benefit from a bow lifting prop and have offered them the use of a Mach Sterndriver that I know has lots of bow lift but for some reason they are not interested in trying it. If you could get your hands on a Bravo 1 22p or 24p I would encourage you to try them both. If you could find a Mach Sterndriver I would really encourage you to try it. I have a 24 Outlaw and have found the Mach to work best for me. There are lots of prop pros here on the forum (Throttle Up and BBlades) to name a couple. Let me know if I can be of any help to you.
TC is offline
Old 01-09-2006 | 09:06 PM
Playn's Avatar
Default Re: 250 Es
The 250 is a nice boat, congratulations!
Playn is offline
berns29scarab
5
09-12-2006 06:47 AM
SED70
0
08-10-2006 01:19 AM
GoingKnots
2
06-09-2004 08:16 PM
markt111
2
05-11-2004 07:20 AM
GaryMMM
Pantera
3
11-19-2002 06:34 AM
