Insta Trim Guage
i have some LED's out on my guage, is there a good parts place to get one of these at or am i stuck with getting it from instatrim. it is the round guage. Thanks Lynn
Re: Insta Trim Guage
I had the same problem on my 03 outlaw had the top led out on both sides, I called them up and they sold me the replacement gauge for $105, 800-386-7470
Thanks, Thats the best $$$ ive seen. Lynn |
But if you have some skill ...in soldering and desoldering....go to Rat-Shack....and do it your self ...you have to de-sealed the Guage....but after you put some Silicone ...... :rolleyes:
Hope this help Best Regard s |
Hope this help Best Regard s I have time to try that...Thanks Lynn |
I have the same problem with my leds going out . has anyone tried to re solder and it work out? ive pulled my gauge apart, there are alot of little fine contacts going into the circuit board how do you get them all hot enough to pull the whole strip off the board??
Originally Posted by 4Lance
(Post 3184811)
I have an Insta trim indicator as well, when I turn the key "on" the lights at the top and bottom of the gauge come on, but, the others don't, regardless of tab position? There are 2 ribbon cables and a 12v wire going to the gauge. I have cleaned the actual indicator pieces that clamp around the trim rams, is there ANY way to troubleshoot the gauge and/or wires to see if it's getting a signal?
Thanks! Michael |
I'm having issues now. Mine is the outside sensor which I'm currently waiting for...
http://www.offshoreonly.com/forums/g...tor-issue.html |
I might have a cut or short in the ribbon cable, is there a way to check it with a multimeter?
Thanks! Michael |
| All times are GMT -5. The time now is 02:09 PM. |
