-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Need some info (https://www.offshoreonly.com/forums/baja/135976-need-some-info.html)
duksrule 07-24-2006 06:56 PM
Need some info
Anyone have a BAJA that has a head with a holding tank, can you send me a picture or even an internet link to the one in your boat? I have a porta pottie with a pump out and want to convert to an actual holding tank.
Do I need to get a vacuflush or are there different kinds? I am hoping to do this fast and for less than a grand. What do you guys think? I have a 342.
[email protected]
Steel Outlawed 07-24-2006 08:08 PM
Re: Need some info
1 Attachment(s)
[email protected]
I added one to my 33 this past winter.
I installed the holding tank under the step in the cabin. I was able to get a 15 gallon under there. It worked out very well. I got the Jabsco toilet. I don't have a picture of the holding tank but here is the toilet.
Here's a link to where I bought my holding tank. They will special make any size.
http://www.plastic-mart.com/
duksrule 07-24-2006 08:19 PM
Re: Need some info
Where did you get the toilet? I guess I need to yank the pottie out and see how much room is in there and how it is secured. I think the tank will be the easy part because it goes under the floor.
duksrule 07-24-2006 08:33 PM
Re: Need some info
Do the electric toilets pump the waste to the tank so you don't need the tank to be right below the toilet? I looked at some of the electric toilets that have the maserator pump on the toilet.
Also should I run it off of my fresh water tank or install it to suck the water in from outside? I run in the ocean so I am not sure what the salt water would do to everything.
Steel Outlawed 07-24-2006 08:33 PM
Re: Need some info
http://www.onlinemarine.com/cgi-loca....htm?E+scstore
Steel Outlawed 07-24-2006 08:35 PM
Re: Need some info
Mine has the macerator built in. I would not go too far away with the holding tank.
I draw my water from the lake. That way you have a unlimited supply.
duksrule 07-25-2006 08:14 AM
Re: Need some info
I am looking at some of these electric toilets and they say one botton operation. Is this one push to fill the bowl and then another push to flush? I think this is going to be my sunday project if I can round up all the parts.
For the holding tank, do they come with a line inside of them for the pumpout and then you just hook your line to a fitting or is there some sort of kit for all the plumbing?
This is what I see that I need. Let me know if I am on the right track
-Toilet of some sort
-Holding tank with hose inside to the bottom for pumpout.
-Connect pumpout line from tank to my original pumpout hose
-Vent filter for holding tank
-Hose from toilet to tank
-Inlet water to toilet plumbed into the fresh water of the boat or thru the haul. (still debating on this sinse I run in the ocean)
-Wire the switch to one of my breakers
Ted G 07-25-2006 08:30 AM
Re: Need some info
Sounds like you are on the right track. You will also need a vent fitting for the hull and for the tank and hose to connect them. Salt water is okay to flush with since it naturally kills the bacteria that make the stink. If you do use tank water make sure you put in a one-way check valve so there is no chance of toilet water backing up into the fresh side. A standard holding tank should have 3 fitting holes- a 1.5" at the top from the toilet, a 1.5" at the bottom for pump out, and a 3/4" near the top for a vent. As long as the pump out hose is attached to the bottom fitting, it will draw the tank almost all the way down with no need for an internal dip hose.
Steel Outlawed 07-25-2006 08:39 AM
Re: Need some info
You probably already have the vent fitting since you have a pump porta pottie. One thing to think about is the pump out fitting on the tank it’s a good idea to put it on the top, that way if it breaks the waste will not run out in the bottom of the boat. I had the fitting put in the top and used a down tube to pick up the waste.
Make sure you have a strainer if you are going to pick up the water from the outside, and a shut off valve. The toilet has one switch only it draws water and flushes at the same time.
duksrule 07-25-2006 08:45 AM
Re: Need some info
My porta pottie has a pumpout and a vent on it already. Not sure if the vent has a filter or not. I am guessing I can just connect those two hoses to the holding tank. Then one hose from the toilet to the tank. For the intake water, where should I mount the water pickup if I go through the haul? I would guess on the side somewhere, below the waterline? Or does that matter, I know my A/C pickup and generator pickup go through the bottom. Any brain surgery to putting in a thru haul fitting other than don't drill through a rib or spare?
Do you have any trouble with your head flushing? I read some reviews that say the 1 inch hose cloggs.
Also how does the flush button work? Push once to fill bowl and another time to flush and pump to the tank?
duksrule 07-25-2006 08:52 AM
Re: Need some info
How far can the toilet pump draw water? maybe I can T into the pickup for my A/C. It is about 10 feet from the head.
Shouldn't the bowl be filled with water before use for some things? Or is there a different switch to fill the bowl?
Steel Outlawed 07-25-2006 09:00 AM
Re: Need some info
My thru hull is on the transom. We just put a brass thru hull below the water line which is just below the hydraulic steering. You do have to buy the extra long thru hull though.
I would install a filter, I bet they did not install one with the porta pottie.
I would not tee into the a/c because it could starve the a/c when flushing the toilet.
I have one button, you push it and it rinses and pulls the waste out at the same time.
