Need some help. >
Need some help.
Need some help.
Old 01-01-2007 | 08:05 PM
Moses's Avatar
Default Need some help.
Well I tryed to start the New Year off right and put the boat in the water today. I fired it up and one of my motors was not blowing water out the mufflers. I no it can't be hard but I have never changed what ever I need to change to suck up water. Any advice would be much appreciated.
Moses is offline
Old 01-01-2007 | 08:18 PM
Nightlife1970's Avatar
Default Re: Need some help.
Well that would be your impeller. I am by no means an expert. I have older 454's the impeller is located below the motor on the left side.
It's not a technical hard job, but getting the thing out can be some work.
Nightlife1970 is offline
Old 01-01-2007 | 08:46 PM
Moses's Avatar
So there is not a water pick up in the out drive?
Moses is offline
Old 01-01-2007 | 10:50 PM
Jim Diesel's Avatar
"Unregistered Gun"
Your freshwater pump pulls from the water pick-ups on the drive the impeller is in the freshwater pump (located on lower left of engine the pump is driven by your serpentine belt). You might as well do both engines while its being done. I think the kit is around $75 bucks.
Jim Diesel is offline
Old 01-01-2007 | 11:14 PM
On Time's Avatar
If you're not familiar with your engines it might be better to take it to a mechanic.
On Time is offline
Old 01-02-2007 | 12:40 PM
You have HP500's, right ?
Here's a breakdown of it:
http://www.mercruiserparts.com/Show_...+PUMP+ASSEMBLY
It is located on the lower starboard side of each engine.
Don't forget to backflush the coolers while you have
the pump off.
JaayTeee is offline
Old 01-02-2007 | 01:07 PM
Moses's Avatar
Thank you guys for the help. I just took a look at it and it looks pretty simple. I didn't know what I was supposed to be looking at, thats pretty funny. First I'll be changing impellers and next adding blowers it's all the same!! Thanks again.
Moses is offline
Old 01-02-2007 | 01:11 PM
One other thing.
note the positions of the hoses,
they can be reversed, if you do that,
you'll have it apart again to replace
the new impeller you just burnt up
JaayTeee is offline
Old 01-02-2007 | 01:32 PM
BY U BOY's Avatar
HOPE THIS HELPS
http://www.offshoreonly.com/forums/s...d.php?t=108106
BY U BOY is offline
Old 01-07-2007 | 10:08 AM
Originally Posted by JaayTeee
One other thing.
I did that years ago. IT SUCKED! Talk about feeling like the world's biggest dumbass.
jswfl09 is offline
