33's NO Anchor Box Solutions????????
:D I have been extremely pleased with my '06 33 w/496HO's , except when I need to throw the anchor out. :mad: What did Baja have in mind for this??? and why did they alter the design from the rest of their boats??. Throwing the anchor is a snap from the cockpit, I stow it under the back seat, then I walk the rope out and tie up the bow, make a loop around my driver cleat and then keep all the slack back up under the seat, the issue is pulling up the anchor especially in wind or even worse a good current. Any ideas here would be much appreciated. Right now its a 2 person job, I get on the bow(wet feet dont help), reel in the rope, pulling 7500lb+ boat, till I reach the chain, then hurry back into the cockpit,(did I mention the bow is wet), then try and pull the boat sideways against the current till I get the anchor up and then stow it back under the seat, the whole time worried about drfting into something. :rolleyes: not whining, just lookn for some ideas from other 33OL owners that have worked it out. Thanks GoodTymn
I hated the way the anchor locker looked on my 272 until the first time I used it. I guess if I had your boat I'd let my buddies tie up first. and use there anchors!
Why not pull it all the way up while you're on the bow, then carry it back to the cockpit to store. Easiest thing to do is have someone else at the wheel that can idle in the right direction while you're doing all this.
Also, if where you're anchoring is calm you can always throw it off the stern instead of the bow.
Originally Posted by jmeng
(Post 2191591)
Here is your answer:
http://www.offshoreonly.com/forums/s...hor+proceedure OR, walk up and untie the anchor line from the bow, and then walk back to the swim platform. Stand on the swim platform and pull in the anchor. I always have the engines running before I pull up the anchor. Tami needs to get behind the wheel and learn. Tell her I said so. She needs to know how to get back home in case of emergency. Tell Joe to tell you about Jennifer's learning experience; and she did great in a real mess of boats and current. |
Originally Posted by Sydwayz
(Post 2191649)
http://www.offshoreonly.com/forums/s...hor+proceedure OR, walk up and untie the anchor line from the bow, and then walk back to the swim platform. Stand on the swim platform and pull in the anchor. I always have the engines running before I pull up the anchor. Tami needs to get behind the wheel and learn. Tell her I said so. She needs to know how to get back home in case of emergency. Tell Joe to tell you about Jennifer's learning experience; and she did great in a real mess of boats and current. Yep my engines are running as well, its usually a very tight fit at Mosquito Beach, so I need to be ready for some manuevering. Good Luck to ya on Saturday on the James, give us a photo shot, :D |
Find a new co pilot or teach her to pull up the anchor :D
The wifey always walks up and pulls up the anchor while I sit in the bolster seat and idle the engine :) The only time I did it i fell off holding the anchor to my chest so it didn't hit the deck of the boat as I did the nestea plunge :(
:D I must defend the work that Tami does accomplish, she sure does steel the show at the dock wiping the boat down, I never go hungry or thirsty, ropes are always at the ready and she did save my boat from a Crazed Pontoon lady that tried 3x to hit me, while I was parking the trailer, + she throws in for gas :D ,, so if anchor issues is all I have, I will be content, especially after seeing a couple Velocity women just get out of the boat, go straight into the cooled down truck and wait for the their man to do ALL the work. If that happenes then I will take your advice. :cool:
| All times are GMT -5. The time now is 10:36 AM. |
