-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   will 35OL with CMI's & labbed props run 80? (https://www.offshoreonly.com/forums/baja/165924-will-35ol-cmis-labbed-props-run-80-a.html)
roadrep 08-17-2007 04:25 AM
It's all about the size of the prop you can spin! If you can spin a labbed 32 at 5000 rpm (and slippage can be kept to about 15% which is average), you can hit 80. If you can't get that labbed 32 to 5000 rpm, then you need a smaller prop and you will not hit 80. Or get enough power to spin that prop. Anything smaller than a labbed 32 at 5000 won't hit 80 with a standard 1.5 ratio bravo outdrive.
