502 ramjet in 272 >
502 ramjet in 272
502 ramjet in 272
Old 08-26-2008 | 08:39 PM
Default 502 ramjet in 272
Anybody tried a 502 ramjet engine in 272 or any boat
ecrain1677 is offline
Old 08-26-2008 | 09:07 PM
spazboz's Avatar
Buddy of mine is running a pair in a 311 Formula. Make sure it is completely marinized prior to using.
spazboz is offline
Old 08-26-2008 | 09:31 PM
Default marinized
What do you do to do that. I had my engine in the boat for two years.
Old 08-26-2008 | 10:11 PM
spazboz's Avatar
Thumbs up You have to paint them BLUE of course!!!
A lot more than just paint was done to these, including:
*Different cams
*Re-worked the heads
*Marine head gaskets
*Upgraded rockers and pushrods
*Added crossovers
*All tolerances were basically built to HP500 specs.
And more including bigger oil-coolers.
We also added oil temp and fuel pressure guages to the boat as well. There was more I'm sure, but thats all I can think of off the top of my head at this time.
spazboz is offline
Old 08-27-2008 | 07:40 PM
Default Engine paint job
Paint job looks good on that engine, I preferred anodize purple, I took the upper have of plenum, because I didn't want to take the intake off also, and had that anodized and then got two piece purple valve covers, and then I have the CMI headers. I will look up some pics. The engine runs OK, ecu needs some tweaking, top speed with a 23 pitch mirage prop, at 4900(wot) was 67 on GPS. I need allot of work in the engine compartment, replumbing, but you only have so much time to boat, and I do some work on it in the off season, but it gets to cold.
Mike
Old 11-04-2008 | 10:41 PM
Any pics yet?
iknowp is offline
nkdski
Baja
15
08-12-2006 11:21 AM
Wateronthebrain
08-01-2004 11:09 PM
XCAV8
18
05-10-2004 09:58 PM
RickR
7
08-06-2003 09:27 AM
dennis rider
6
06-11-2003 06:53 AM
