Hey XT-Innovator >
Hey XT-Innovator
Hey XT-Innovator
Old 02-28-2009 | 03:43 PM
  #41
That's what we need. I don't know how much it takes to do a platform. It is for a late model 33, they were a little bigger than the old ones, right? Anyway do you want to PM me with some info?
redbud35 is offline
Old 02-28-2009 | 08:54 PM
  #42
I hate that tape crap. Doesn't stay down no matter what kind of glue you use. Too expensive for what it is, too IMO.
I just had my platform re-powdercoated, and I am going to use some stuff that you can get in a spray can that is similar to the plastisol coating GM used to use on their rocker panels. I'm just going to do the tops of the tubes. This stuff costs around $20 for one spray can, but that should be enough.
I've seen other platforms with a rough surface of some sort. Don't know if this is the same stuff, but I am going to give it a try.
pwam1 is offline
Old 03-01-2009 | 01:02 AM
  #43
Are you sure your not thinking of the rubber they used to use. I have never had a problem with the tape. It looks alot better than the rubber inserts they used to use.
redbud35 is offline
Old 03-01-2009 | 08:52 AM
  #44
I get $30.00 (for none TBM members if they admit to it its double) roll that is 60 ft long enough to do your platform almost twice..... How is that expensive ?
Redbud you can call me at 734-586-0448 Thanks Brian
brian41 is offline
Old 03-01-2009 | 04:32 PM
  #45
Thanks Brian, I will be in touch.
redbud35 is offline
Old 03-01-2009 | 05:17 PM
  #46
Naw, I have 50" of that rubber insert stuff in white that I bought from Extreme Marine a long time ago. I'd damn near give it away just to get rid of it. Seems like I paid over $2 a ft. for it.
I've had the tape on several platforms. After it sits in the sum for a while, the edges will start to curl. I've tried everything to keep them down. Going to do the other spray texture stuff now.
pwam1 is offline
Old 03-01-2009 | 06:51 PM
  #47
Are you going to put it only where the tape was? That sound like a good idea. Mine is curling up also. The tape from Brian is far a friend. Let us know how that works.
redbud35 is offline
Old 03-02-2009 | 04:40 AM
  #48
boatman22's Avatar
Who was the rub rail supplier for 1996 models?...Looked at Taco but they don't list Baja.
boatman22 is offline
Old 03-02-2009 | 07:36 AM
  #49
eddie's Avatar
Default Switch cover?
XT I need an "engine hatch" swtich cover for 2001 33 Outlaw - by chance do you have one? I have replaced all the other, but can't find this one. Letters are wore off a bit. I'll take two if you have them, I have a buddy that needs one too.
eddie is offline
Old 03-02-2009 | 10:06 AM
  #50
Custom Interiors & More
Eddie,
Are they the square style in black, or white.....or maybe the engraved more rounded style? The best ones to have are the engraved style we started using until 2008. I will look to see what I have?
XT
Attached Thumbnails Hey XT-Innovator-stereo_switch.jpg   Hey XT-Innovator-stereo_blk.jpg   Hey XT-Innovator-switch_covers.jpg
XT-Innovator is offline
