-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Got my Dyno #s!!! (https://www.offshoreonly.com/forums/baja/206876-got-my-dyno-s.html)
kennyo 04-14-2009 08:38 AM
Got my Dyno #s!!!
I went last Wed. to finally dyno tune my engine combo. My friend Eddie Young provided the tuning and advice. We pulled it to 5600rpm and got 843hp and 828tq @ 8psi! Not a bad # considering the ignition started cutting out and my injectors were maxed out @ 5000rpm. I'm out of money so other than the ignition fix I'm going to change the blower pulley and try to make the injectors live for a while.
This is on stock internals(515 C.I.) and cast iron GM heads. Thanks for the cam Bob!
RunninHotRacing163.1 04-14-2009 10:11 AM
Niiiiice BIG Daddy , sounds like your in good hands with Eddie Young ... whats this out of money chit ???? how much ya need for the girl:eek:
Dock Holiday 04-14-2009 11:21 AM
Those are great numbers!
Keep us posted on how she does in the boat.
Good luck and ENJOY
Smitty 04-15-2009 09:37 PM
I've got a set of 60 lb short body injectors that should plug right in. Let them go for $275.00 + shipping. They have less than 10 hrs on them.
Smitty
Fenderjack 04-15-2009 10:05 PM
Great numbers for sure esp on them CI's
Smitty
I think he will need more then 60's for that hp..
John jr
AIR TIME 04-15-2009 10:44 PM
nice I can't wait to get mine back on track:ernaehrung004:, since I spent glass money on konrad:evilb::ernaehrung004:, whats two more or three months:eek:
baja27 04-16-2009 08:51 AM
Those are some great numbers, what spark plugs did you guys use?
articfriends 04-17-2009 12:50 AM
Smitty,I'll take them injectors if Kennyo doesn't want them assuming they asre high impedance,I have several projects started that could use them,the "other" Smitty
articfriends 04-17-2009 12:53 AM
Kennyo,are you still going to run the stern jack? I can't wait to see were you end up for top speed when it's all said and done. I might have a few props for you to try if you need them,Smitty
kennyo 04-19-2009 11:40 AM
I do still run the stern jack. I was a little disappointed with my speed this weekend. 86mph@5600. I'm running a 30p bravo one now so hopefully I can prop up some and gain some speed. I was really wanting in the 90's. I've got way to many Nordic Heats beating on my ass down here!
