How fast should my 272 run???
I have a 1994 Baja 272 equipped with a 330hp merc 454, bravo one drive and 21p mirage prop.
Trimmed significantly with almost no fuel, and by myself on glass water I get the speedo to show 56, handheld gps says 53/54, this is @4600rpm.... I posted in the general section, and Air Time seemed to think this boat was running pretty slow. I am considering some power upgrades this winter. Is this running slow, or am I right around what it should run. Thanks in advance! |
I had a 260 with a 330 and it would only get about 55. So for a 272 I would say that is pretty close. You seamed to hang pretty good at St.Clair though.
Originally Posted by Nightlife1970
(Post 2904353)
Either way, right about the same speed. The run was awesome, definitely was catching some good air.... I will be back next year. You coming around for the Raft off or cumberland? |
I also would think that speed seems right. Can you turn a 23 prop?
I had a 1997 272 with the 330 LX MPI,,,, turned a 23 Mirage plus at over 60 MPH.
Originally Posted by SmurfOnAGixxer
(Post 2904346)
Trimmed significantly with almost no fuel, and by myself on glass water I get the speedo to show 56, handheld gps says 53/54, this is @4600rpm.... I posted in the general section, and Air Time seemed to think this boat was running pretty slow. I am considering some power upgrades this winter. Is this running slow, or am I right around what it should run. Thanks in advance! i see 62 gps on my 99 252 with the 454 mag mpi that is at 385hp bone stock, my prop has been worked to see 5000rpm have a mirage plus 23p on |
Originally Posted by 30outlaw
(Post 2904517)
well 4600rpm is not enough, you should be up around 5000rpm, that will be maybe 2 more mph......what kind of power upgrades??? it takes probally 10-15hp to see 1-2mph
(Post 2904439)
isnt a 260 actually a 26ft boat? The 272 is only a 25ft boat with a 2' integrated platform?
(Post 2904346)
Originally Posted by HTRDLNCN
(Post 2904560)
I would imagine running in some nice chop instead of glass water would get you up a couple mph as well.
| All times are GMT -5. The time now is 02:14 PM. |
