Anyone know what I should be running with 500-540hp on 96OL SST
Had an engine built.. 500 to 540 hp in a 96 outlaw SST.
Bravo x drive. Sport tubes and open headers. does anyone know what speed I should be getting with this engine.. running Full MSD ignition. stock 96 454 thunderbolt fuel pump. with a 26 4 blade was running 4500 to 4600 rpm.. max opperating range is 5200 rpms. was up around 70 mph..... would a 25 3 blade mirage plus give me more speed and stability? |
Three blades are going to be the fastest
on that boat.....the drive is fairly deep on those. I would think that you want to get your rpm's over 5k too. |
Originally Posted by Outlaw00024
(Post 2921357)
I had a 489 w/ around 500hp in my 89 226 sport, 4000# boat. I was in the same rpm and speed range with a B1 26, after putting a 25 mirage on it I was runnig 74-75 around 5100rpm.
http://washingtondc.craigslist.org/m...295681258.html |
24 Outlaw? Sounds like you need to drop down to at least a 25 Bravo if you stick with 4 blades, maybe even a 24. If you go three blade probably a 25 Mirage plus. And trim that baby to the moon!
I have a 25p mirage plus on ebay now. It is in the swap shop now but had no contacts on it for 2 weeks so put on ebay. anyways here is the link. http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
Originally Posted by Fixxxer22
(Post 2922327)
Originally Posted by My Addiction
(Post 2922553)
Didn't I sell you that prop, why cant you use it. Sorry it didn't work out
oops, I didn't even look at the ad. a prop, is a prop.
| All times are GMT -5. The time now is 02:05 PM. |
