1995 baja 236 ?
Does anyone own or have experience with a 95 baja 236? I purchased boat with a 496 mag and curious of what prop would be my best bet for all around performance and speed. Currently has a 21p mirage plus and not to happy with overall speed 45-50 mph. Boat has original bravo 1 drive that was originaly powered by a 454. 496 mag 375hp was installed and everything else left the same. In reading motor specs WOT should be around 4600-4800 rpm. Im able to go over that with 21P prop, looking for a prop that will keep me in that range with best performance and speed gain. Runs 30mph at 3500rpm currently. Im not sure of gear ration in bravo1 buts its original drive fron 1995. Any suggestions are greatly appreciated.
Originally Posted by wilstruck
(Post 2939207)
baja 236
Yes it is uncommon but thats one of the reasons i like it. Im getting 50ish on gps but rpm's will climb up over 5000 and i have to back off throttle. Im afraid of gernading the engine by over reving due to to small of a prop. This past weekend i happened to look down at rpm gauge and it was reading up over 5300 rpm and climbing. I was also given a new michigan wheel apollo 23P (part#993026) with boat i have yet to try. Im sure it will help but is it enough? What was your stock bravo 1 gear ratio?
(Post 2939739)
Where do you live/boat at?
mirage prop work the best and give you top speed !!!! i try a lot of props the mirage ,not the plus.:boat: the plus runs 200 more rpms then the old mirage .rember one pitch is 200rpm. you need to no wot is on your motor and prop it closest to that number and your boat will run the best:party-smiley-020:
Are you sure your tack is accurate?
Originally Posted by G-Spot
(Post 2941719)
Baja 236
Originally Posted by jeffswav
(Post 2939984)
What was your original gear ratio in 94 with a bravo 1? |
Havent been able to get out on it recently do to work schedule and weather but will try again as soon as i can get out! Had an issue with oil temp rising at WOT but new pump should correct that next time out. Seems like im constantly working out the bugs since i purchased the boat.
| All times are GMT -5. The time now is 11:29 PM. |
